SOURCE: cant load paper into my printer
Hello, My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to loading the paper . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue. Please try below steps if you want to know how to load paper in to the Feeder.: To load separated sheets of paper: Humid conditions may cause some sheets of paper to stick together. If the issue still persists, then I recommend you to look in to USER MANUAL that is provided along with Printer for instructions on loading Paper. Well, for your convienience I'll provide you with steps that helps to access USER MANUAL................. Steps are : This should resolve the issue for you. If you need any further assistance on the issue, you can mail me at [email protected] . I'll be glad to help you. Bye.
Important: When loading paper into the feeder, make sure you are using separated (i.e., cut) sheets of paper. Banner paper that is connected end-to-end should not be used unless you are specifically printing a banner.
SOURCE: Lexmark X2350 Paper Feed Troubleshooting
Check to make sure there arent any stray paper fragments in teh paper path. Also try taking a pencil eraser to the paper pinch rollers GENTLY.
SOURCE: paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
SOURCE: Hi, my name is Fernson
Load "MP" means to load media into the Multi Purpose feeder , which is in the front of the printer.
This can be caused by several things, all of which are easy to fix.
First, open the printer driver and verify the correct selection of media draw.
Next, ujse the printer's paper menu to set the proper tray.
Lastly, make sure that the print file going to the printer is not asking for the MP Feeder.
SOURCE: have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Testimonial: "Thanks for your help. It looks like this can't be repaired though so I'm getting a replacement."
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
We would like to know more about the lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
Since the printer will print, for us to give the common light sequences, please provide us information which light is orange on the printer.
This light sequence means that the printer prompts you to load a single sheet of print media in the manual feeder. What you can do is load paper into the manual feeder and press Continue to resume printing. Press and hold Cancel to reset the printer.
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
