Motorola MC9190-GST Logo
John Huls Posted on Dec 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen Flickers Have 34 Scanners, approx half have a screen flickering problem, almost as if a button was benig held down. You have to remove the battery to reset.
SysAdminGuru
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 61 Answers
  • Posted on Dec 03, 2013
SysAdminGuru
Expert
Level 2:
Cheetah:
Answers
61
Questions
0
Helped
16280
Points
111
Motorola has had a lot of issues with the 9000 series displays.. your best bet is to RMA it. and get it fixed.
1helpful
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
1helpful
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
I've switched of my ipod....later ven i tried to restart,it had frozen.....plz give me a solution to restart it
if it is an iPod touch, Hold down the sleep button and the home button together until the screen flickers and you then see an apple logo. If it is an iPod classic ,nano (except the latest), mini, hold down the select and play button together until the screen flickers and you see an apple logo.
After resting my unlock 3gs iphone , the phone frozen on apple logo.
Try holding the home button (one on the front of the phone) and the power button (at top of phone) down both at the same time until the the screen flickers off, then keep held down or repeat this until the apple logo reappears.
Hope this helps
(Please Leave Feedback)
1helpful
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
I have just re-installed my acer scanner after approx. 2 years of non-use. as I plug the power in the green light comes on , flickers for a moment or two and then goes out. when i click on the Mirascan...
Replugged it remove it and clean it and then plugged it again and then check what message comes to u r screen if the message comes so install it one more time or if it would not connect so change the port of plug and then restart u r pc and try that problem will solve
2helpful
Samsung g600,dropped,buttons,sound not working and screen blanks
Hi, I have a Samsung G600 Service Manual PDF if you want it, and it will tell you all the disassembly and reassembly instructions!
Let me know Harvie
Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
