Televison & Video Logo
Anonymous Posted on Dec 20, 2012
What is the VESA Standard for a 32in AVOL
I need to know the VESA measurements for a wall mount.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Dec 21, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986853
Points
237762
Check this link to know more.
Mounting bolts for emerson lc401em2f
I had the same problem, there is documentation on the web or in the manual, total BS and it is not a vesa standard mounting bolt, hang the engineer. Fortunately I work at a shop with bolt inventory to experiment with, you will need four 5/16 x 1 inch us standard. Enjoy!
I need to mount my Olevia 237-t12 to the wall, but I can't find the manual to know what VESA mounting standard it is. What size mount do I need?
Just measure the 4 monitng holes spacing on the back in millimeter to get the VESA number.
It should be one of these: http://www.mountcenter.com/VESA-Mount-Standards-s/367.htm
pattern.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
1helpful
2answers
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
I need a wall mount bracket
Most if not all tv's are VESA compatible. All wall mounts are VESA compatible, meaning you can buy any wall mount you see fit to mount your tv.
I'd look into Sanus brand mounts, they're pretty decent.
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a...
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
