Question about Mitsubishi WD-Y57 57" Projection HDTV
Air flow error message again and again....
I did my own troubleshooting and found that my lights indicated that my "room temp" was too high..... My TV sits in front of a window that was opened and it being 40 degrees outside, and I still get the error. Although it did work a few times. Now just to locate the "air flow filter" I've told to clean....help me out...please.
  • Coolade Dec 21, 2012
    Into the Tv as far as my tools lets me....can't get into the fan that cools the lamp and found no mesh. Thinking there still may be a filter I can't seen to find but don't want venture into the other side of the Tv....other suggestions??
  • Coolade Dec 22, 2012
    Alright!! So i kept digging into my TV after i got more tools...did not find any mesh or filter in my model "Mitsubishi 57" WD-Y57 2006" but took out the 3 fans (Optic engine, lamp cooling, and lamp air exit fans)...cleaned all the dust off all of them and then >blew>SD Tech<< for the intial solution!! Thank you!! :D
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
A few of these sets did have a issue, the lamp cartridge had some fine metal mesh around a few places where the airflow from the cooling fan contacts it, that mesh if there gets blocked with dust and will give this error as it is really the set detecting the lamp temp is too high.
If you find that, clean the mesh free of dust, careful not to drive the dust inside onto the lamp face itself.
Other than that dust on the fan that cools the lamp can slow the fan just a little and the set will detect this also.
Posted on Dec 21, 2012
3 Suggested Answers
6ya staff
SOURCE:
Willie Howell
  • 1030 Answers
SOURCE: Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Posted on Jun 04, 2009
Willie Howell
  • 1030 Answers
SOURCE: tv says air flow problems
ok what you have there is a faulty thernal sensor nitisubishi has issuued a bullitten to serice centers so check with local service center the repair might be covered under warennty
Posted on Jun 18, 2009
I have happily used a chat room "Bible Fellowship" on AIM but it has suddenly stopped printing what I type. All I get is an error message, "we cannot send your ...
sir maybe the policy of this chat room doesnt allow u to type websitezs if u r realy type websites links!!
rate me fix you!!^^
Aug 16, 2008 | Computers & Internet
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
My LG room air conditioner has an error message "C2". Please advise what this means and what to do.
According to the owner's manual C2 indicates "an open circuit in the indoor pipe thermostat. Unplug the unit and contact your authorized LG Service Center." To locate the closest Service Center to you, go to the following link. http://www.lg.com/us/support/repair/support-repair-provider-lookup.jsp
If however, you confused C2 with an F2. "F2" indicates the fan speed setting and the unit is working as it should.
I hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | LG Heating & Cooling
I have an AC unit with the model # PDH12K3SD-C the unit stops working and flashes an error cod = "06" anyone know what the error code means?
According to the Owner's Manual if the Error Code flashes "06" the O.D. coil Temperature > 175 Deg
F for 2 consecutive minutes. (Heat Pump models only).
The action taken by the unit is Alternate flash set point and error code. Shut unit down for 5 minutes, then try again 2 times, if fails the 3rd time, then shut down unit.:
All of this is can caused by several things:
• Dirty filters
• Dirty coil
• Fan motor failure
• Restricted air flow
• Improper refrigerant charge
• Restriction in refrigerant circuit
The dirty filters, dirty coil and restricted air flow you can troubleshoot and solve yourself. The reaming ones should be handled by a an authorized service technician.
Here's a link to your Owners Manual, that you can download and print for future reference.
http://www.ajmadison.com/ajmadison/itemdocs/92008705_9-07_PTAC_IO_manual.pdf
Hope this helped to to troubleshoot and solve the problem . Please let me know. Thanks.
Jun 10, 2011 | Friedrich PDH12K3SD Air Conditioner
What is code 23 for pontiac grand am is it vacume leak
Wow these are hard to find!!
Diagnostic codes for 1987 Pontiac
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Vacuum Control
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
52 CALPAK Error
55 ECM Error
If you have your owners manual they should be in there. I couldn't find one online but did find this.
Future reference
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-28.htm?once=true&
I hope these helped you
Nov 26, 2010 | 1987 Pontiac Grand Am
NO HEAT. Blower / fuse / relay / fans - are OK. Noticed low level of antifreeze. Topped off & blead system several times. Topped off again. All operating temps are good. No wet floor board discovered...
the flap directing air to the heater core may be jammed. otherwise, the valve on the in flow side of the hose may be frozen, or partially restricting the flow of hot coolant. good luck!
Nov 06, 2010 | 2003 Chrysler 300M
MSH12TN Left green light keeps blinking and the air conditioner keeps going off. Room temp is over set temp.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Temp. Problem
Before you call in the cavelry, check the rear fan access cover and open it to check the fan. Please check this with the unit unplugged. Make sure that the fan turns freely and that the air path is clear and clean. Once cleaned, try the set again and pay particular attention to whether or not the fan is spinning. You should be able to feel the air flow. If there is air flow, and it does not feel really hot, you may have a defective air flow sensor or temp sensor. Let the tech know what you find if the celaning does not resolve the problem.
Keep us posted.
Dan
Mar 19, 2009 | LG 52SX4D 52" HDTV
Mitsubishi WD-Y57 57" Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
