On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
