Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
SOURCE: ice maker won't work
Temp needs to be down to 0 or below for ice maker to activate. once that happend arms that push ice out will go around and made switch in end of ice maker that turns on water selenoid valve that adds water. this could also be electronic switch. main thing is its cold enough to activate. If it don't work then Ice maker may be bad or no power getting to it. turn freezer as cold as you can may mean setting refrig side warmer. If it has coil under refrig clean it out. Air around frig should be 68 - 75 degrees if poss.
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
