When turned on half screen green half picture once warmed up (bout 20 mins) all good, As I understand it this is a fault related to capacitors? is this correct
SOURCE: rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
SOURCE: line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
SOURCE: WHEN I FIRST TURN ON TV ALL I GET IS VERTICAL
this may be a problem on the 5 volt line in the set, there is a constant 5 volts running through it even when it is off....so long as its plugged in.
There may be condensors that are open on the 5 volt line.. after they warm up they start to function more proper. but being that they are leaky..they are no longer doing thier job of keeping voltage steady until they warm up.
i do not condone this but if you were to open it up , im willing to bet you have a series of swollen or blown condensors that are not doing thier job on the pwb (power supply board) if thats the case its a 30 minute fix for a technician. Id like to discuss this with you further , i do have a couple questions that may help me diagnose this.
SOURCE: When we turn on our tv in the morning the left
Call Sony my friend. I have the same exact issue with the same model. They already have a recall for the 46"XBR4. Let Sony know that us 52" owners are having the same issue. I'm essentially calling them everyday until they fix it.
