Light cycle was about 32 minutes now 50, heavy has increase to 96 minutes, why has this happened?
SOURCE: wash cycles are increasing in time required to complete
Could be a plugged filter screen in either the hot or cold water supply hose. Longer filling time aads to the cycle time.
SOURCE: The wash time continues to increase on every
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
