Originally a picture was frozen, camera wouldn't turn off. Let the charge run out and re-charged, when i turned it on, the Olympus logo froze on the screen and i can't turn it off again. It's new! Only charged four times now, one of those times was due to this issue.
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
SOURCE: Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
SOURCE: Black Screen
I just started having this problem with my canon PowerShot A310 and checked their service website which says "Effective immediately, and regardless of warranty status, Canon will repair, free of charge, products exhibiting the above-mentioned malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair." Here's the website link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9829
SOURCE: my olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING.... battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
SOURCE: Lens goes in and out four times then ask to turn power off and on
Option 1:
Try Initializing the Camera as follow; Initializing
the Camera will reset the settings of the Camera to the factory
settings including date and time. It will not delete any data saved in
the Camera.
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
