Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty. Replacement parts can be
purchased at any of the following web sites: partsselect.com -------------------- Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
SOURCE: Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
SOURCE: tHE ICE MAKER IS NOT WORKING
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
ice. For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the
water is not filling in the ice maker chamber then it's clear that ice is not
getting made due to no water in the chamber. For no water filling, the problem
is either water supply valve turned off so water is not filling. Turn on the
water supply and it will fill. But if the water supply is turned on then the
other possibility is ice blockage in the water fill tube. There is a tube from
which the water runs and enters the ice maker chamber. If this tube is blocked
then water will not enter the chamber. The tube needs to be defrosted, by using
hair dryer. This procedure melts the ice collected in the tube and
water starts running again. But if water fill tube is completely
clear and no ice blockage or any other blockage. Then other possibility is
water valve. This water valve is for letting the
water in the ice maker. The water valve open only for 7 seconds and
in this time the water fills in the ice maker chamber and then water
valve closes and the same procedure runs again in the next water
filling cycle.------- The main valve on the back of the fridge section. This main valve lets the
water enter the refrigerator .In most of the cases the fault is water valve . ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve is faulty. Replace the valve.
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
or the water valve at the back of ice maker is faulty. Replace the valve.
Helpmech.
water valve at the back of ice maker unit. This water valve is for letting the
filling cycle.------- In most of the cases the fault is water valve at the back of ice
maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is
Helpmech.
water is not filling in the ice maker chamber so it's not making ice. If the water
is not filling in the ice maker chamber then it's clear that ice is not getting
made due to no water in the chamber. For no water filling, the problem is
either water supply valve turned off so water is not filling. Turn on the water
supply and it will fill. But if the water supply is turned on then the other
possibility is ice blockage in the water fill tube. There is a tube from which
the water runs and enters the ice maker chamber. If this tube is blocked then
water will not enter the chamber. The tube needs to be defrosted, by using hair
