Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool cabrio washer keeps flashing code F50
MOD # WTW6600SW2, SER # CU2672701, TYPE 580
STARTED A LOAD OF WASH, WHEN CLOTHES WERE BARELY WET, CODE STARTED FLASHING AND WILL NOT CLEAR AFTER HITTING THE PAUSE/CANCEL BUTTON AND HITTING RE-START
Washer was bought new last year, unsure of date at this time.
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 28, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036153
Points
35540
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Hello~ We've been struggling to repair our Whirlpool Cabrio washer - Model - WTW6600SW2. We received the codes F50, F72 and just F - we replaced the stator motor and RPS sensor kit; however, we are...
Hi
Please check this list of codes in whirlpool cabrio.You will get a detailed idea about code F 50 and the test to be performed:-
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
I keep getting the F50 code and I also got the SD code a couple of times. I followed the manuals directions and pressed pause/cancel and it still came back. We also unplugged the washer for about 30...
The "Sd" or Suds Detected error means that you used too much detergent. Reduce the amount of detergent that you use, and properly measure it.
When you receive the "F50" code, it means that the motor position sensor does not sense that the basket is moving. Remove any remaining packing material from the tub.
Hope this helps.. :)
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
7helpful
I need the service manual for a Whirlpool Cabrio WTW6600SW2 to find out what the code F50 mean and how to replace RPS sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
I am trying to wash clothes with my whirlpool cabrio he but it keeps stopping and saying f50. what should i do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
1helpful
Code f 50 on cabrio WTW6600SW2 what is the most likley cause
Silverdragon posted the following yesterday about this issue...
http://www.fixya.com/support/t4267679-wtw6600sw2_cabrio_giving_me_f50_code
F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70 codes
4helpful
Wtw6600sw2, cabrio giving me the F50 code. Any ideas as to what that means?
Washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
2helpful
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
3helpful
2answers
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
