I have a 42" LG TV and 5 mins after plugging tr-nx609 into HDMI, the screen goes black on TV and the LG freezes so i have to unplug it. This has only started recently but happens every time on both hdmi inputs. There are no problems with using other inputs directly (ps3, cable) and when i plug the Onkyo receiver into my Toshiba 32" TV, ot problems there either. Any ideas, I have not found this on any forums. Any advice much appreciated. Thanks. Ross
If using a box disconnect it and the set from power for a few minutes and try again.
Next I would remove connections one at a time with set off and try to see if one is creating this issue. HDMI does not like to be connected when a unit is on or power connected to it.
Thanks for the reply. I have tried different connection confiurations with everything unplugged a couple of times and no luck. Everything plays fine to start with, no issue changing from one source to another, so I don't think it is the initial connecting. It can be from a minute after start up to 10+ that it happens. But happens every time when Onkyp connected and Never when using any other HDMI source. Also Never when using Onkyo with other TV
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
SOURCE: RCA LCD 42Lfhd37 Unusable signal
have you tried calling to the store you purchased it from and seeing if they will print you a new receipt. alot of stores will do this for you. also some times the store will cover the tv under manufacturers warranty and will send someone out to your house.
hope this help
please feel free to ask if you have any other questions.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
sorry should be tx-nr609
