I purchased the proscan model PLCD3992A-B and when I was able to buy (what I thought was the same) out-of-box tv a few days later I got it because I was so impressed with the first one. It hooked up fast but I was not able to get the remote to work with this second tv even though it would work on the first. When I went back to the store I noticed there was a different looking remote and the clerk allowed me to take home to see if it would work. It did! Thats when I noticed the model numbers (as shown above) were different. The stands are also different whereas one has 'feet', the other a 'solid' base. Now I am really curious as to what are the other differences that I am not able to see. Is one better than the other? Is one a newer model? Exactly what are the differences between these 2 models Proscan models PLCD3992A and PLCD3992A-B Thank you for your time
SOURCE: I have tried to program my FiOS Verizon remote
Thank you. I did solve my problem with some diligence. The instructions from Verizon were correct. I realized that there are two buttons on the Verizon universal remote that look alike - the "play" arrow and the "fast forward" double arrow. Once I used both of these buttons in the proper sequence, reprogramming the TV remote with the new code worked.
SOURCE: need to remove base from Proscan 32" TV
The stand
can be removed by unscrewing six phillips-head screws from the back panel. A
plastic insert plate is provided to cover the bottom hole that is left when
removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
SOURCE: can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
