Question about Samsung Digimax D53 Digital Camera
My camera won't turn on!
For the past couple of months, my camera has not been turning on. I've tried numerous pairs of new batteries, but they aren't doing anything! I have no idea what could be wrong, and I have taken no steps in trying to solve this problem myself.
  • 13 more comments
  • Anonymous Nov 14, 2007
    it beeps and flashes a gren light when turned on, i changed the batteries and nothing happens
  • Anonymous Nov 21, 2007
    Makes a buzzing noise and doen't turn on.
  • rrrjr Nov 27, 2007
    Same problem, camera wont turn on only makes a clicking sound.
  • Anonymous Dec 07, 2007
    i turn it on and it pops up Low Battery! it make a repeated beeping noise.
    I could turn my camera on and it would make a beeping sound then go off so i sent it in to be repaired and they said that it was sand, water, and dust damaged but now i see it is just the camera. Everybody here has the same exact problem how funny!!!
  • Anonymous Dec 08, 2007
    my camera is doing the same thing and i have tried new different batteries ,it must be a lemon .i guess they put a expired date on it so i would get another camera that would last almost 1 year. help me if you can.......................
  • dune52 Dec 12, 2007
    Mine wont turn on and I tryed changing the batteries. I have no idea what is wrong with it. I have had it less than a year when it started to not like to turn on and now I cannot get it to turn on.
  • Anonymous Dec 16, 2007
    Well mine turns on for a couple seconds then turns off again
  • Anonymous Dec 21, 2007
    I have the same problem, my camera eats batteries, I can use it for 5 minutes and then have to replace the batteries, or it will flash on and then off again. The lense has also occasionally stuck open.
  • Christine Amstutz Dec 29, 2007
    I used to have a problem with my camera. I agree with the other suggested solution - switch to lithium batteries. My camera has had no problems since then and the batteries last for a pretty long time. I used Energizer e2 Lithium batteries and they work great!
  • Anonymous Jan 13, 2008
    my Digimax D53 wont turn on i have tried different batterys and it still wont turn on....can somebody please help me?
  • chaufferman May 10, 2008
    samsungd75 wont turn on get green light
  • bballplayer May 17, 2008
    My camera won't turn on. And i am using those Energizer e2 Lithium Batteries and then the camera won't turn on but it makes a weird noise.
  • randomgurl57 Jul 31, 2008
    My Camera Takes pictures fine but the screen dose not turn on
  • dylansdad Aug 13, 2008
    camera wont stay on beeps then goes off
Here in my side...
I do suggest that you have to set the correct battery settings in the camera...
Advised to set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
For other camera you just have to go to setup... and look for battery type...
Posted on Jan 14, 2008
  • 3 Answers
Yes yes yes i think i have solved the problem with s1065 (if your camera lens is stuck on open and makes a bleeping noise-then read on ) its not the battery's it seams the lens motor is a bit temperamental ...... grip lens as if you were opening a jar ,with the thumb and index finger gentle twist left and right with little pressure thus should solve you problems ......IT DID ON MY S1065 STEVE FROM MONTROSE SCOTLAND
Posted on Feb 11, 2010
    New Friend:
Solution 1 is right on....only something is stuck behind my lense and i cannot get it out.....GRRR
Posted on Feb 05, 2010
Had this problem, then i looked at my lens it was still out and i noticed it was bent. Luckily for me a little muscle i popped it back right and now it works :D
Posted on Jan 29, 2008
Check the batteries...if they're alkaline, switch to lithium, that's what worked for me just a couple of days ago, I was having the exact same problem OR talk to your camera retailer, either way works.
Posted on Jun 21, 2007
I have the same exact problem
Posted on Dec 28, 2007
    Genius:
  • 2,985 Answers
Samsung Technical Support team. If a year or less or perhaps a little over old There may be a manufacture issue with this. If not and they are unable to help replace the camera there is no repair option that is economic
Posted on Jun 18, 2007
2 Suggested Answers
6ya staff
SOURCE:
t00nz
CameraR
  • 4738 Answers
SOURCE: My camera won't turn on!
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on Feb 22, 2009
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
Feb 22, 2009 | Cameras
Sony Cyber Shot, camera wont turn on
Try cleaning the connectors inside the battery compartment, top and bottom and then replace the rechargable batteries with disposable alkaline batteries and try again. If this works then the problem may be the rechargable battery pack.
Nov 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
Whats wrong
What kind of batteries are you using? I had this problem with a Samsung camera when using alkalines. It behaved much better with rechargeables or oxyride batteries.
Oct 26, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
6,778 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
