SOURCE: dell latitude c510/610
Hi foforera,
This sounds like either a HARDDRIVE PASSWORD or a SYSTEM PASSWORD. Especially if the prompt appears every time you turn on the PC. If this is the case, all I can say is that you should write down the exact message and call up or chat with Dell Technical Support since they are the only one's who can give you a password for that.
If the password you're talking about is the Windows logon password, then I would recommend that you find someone who has an administrator logon, and from there you can actually remove the password of your account. You can also go into Safe Mode, then log into the Administrator account, and from there remove the password on the account you are using.
Hope this helps!
Peace! :)
SOURCE: PCI modem downloadable driver for dell PP01L c510/c610
Hi Princess!
You will find the drivers you need here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_CEL_C510&os=WW1&osl=en&catid=&impid=
Just follow the link, download the drivers you need and install them
Good luck to you!
Please take a minute to vote
Nic
SOURCE: need a driver for pci modem for my dell PP01L c510/c610
Here is a page to download drivers for a C510:
C510 Downloads
Here is the page for the C610:
C610 Downloads
Select your operating system if it is different than XP.
If you are not comfortable downloading from these pages, consider going to:
Dell Support
Click on Drivers & Downloads and follow the prompts to enter your service tag number. That way it will take you to the exact site you need to download. If you need more help, just comment back.
Thanks for using Fixya.
SOURCE: how do i install a wireless card in a dell latitude c510 c610?
There's two slots toward the back on the left hand side that you can use but this will be for cards that will stick-out. Alternatively (my solution) is to open the panel under the laptop where you'll find recesses for additional RAM and one for inserting an internal Wi-Fi card.
SOURCE: pp01l model no.i need a sound driver for the dell
Your drivers are here. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D510&os=WW1&osl=en&catid=&impid=
alias for http://support.dell.com and put in your model for the search
