Question about Hitachi 42PMA400 42 in. Plasma Television
I have a Hitachi 42 PMA400e Plasma TV. I want to be able to allow sound to come out of the TV, and simultaneously have sound coming out via the headphones. Currently plugging in the headphones mutes the TV. Is there a setting that allows this?
6ya staff
SOURCE:
Anonymous
SOURCE: hitachi plasma tv 42pd380ta problem
Hi, the ysus board on the left side looking from the rear of the plasma has blownup, this is a very common problem with 42PD380TA, if the unit is under warranty you are lucky otherwise hitachi charge alot of mooney for service kit.
I have seen 7 hitachi plasmas in 3 months all with the same fault.
HITACHI dont accept there is a production Fault
Posted on Jan 23, 2008
Anonymous
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
Anonymous
  • 186 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Posted on Apr 29, 2008
Paul
  • 224 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
Posted on Oct 05, 2008
Anonymous
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
I have an Hitachi 42 PMA400e Plasma Tv. The problem is that when I switch the unit on it gives me a picture for a brief second before going blank. This is happening on both the Video 1 & 2 channels....
I also have this television, and it baffled me too. Apparently the 42PMA400E isn't so much a television, it's more of just a "display unit". It hasn't got any built-in channels (can't even connect an aerial into it) and hasn't got any speakers either. To use as a television, you need to connect a reciever (I use a DVD player, as I only use it for the Xbox) to it to display the video, and get some surround sound speakers to connect to the DVD player.
Jan 17, 2011 | Hitachi 42PMA400 42 in. Plasma Television
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
May 31, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42PMA400 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
