SOURCE: "Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
SOURCE: 4 GB doesnt work
I believe this camera only supports SD/MMC cards, not SDHC cards. Go to the kodak site to see the detailed specs. Not all devices support SDHC - most new ones do - but some only support the older SD cards.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10002&pq-locale=en_US&_requestid=1803
SOURCE: My kodak easyshare c180 wont read a memory card
You should probably get a USB card reader, take the card out of your camera, put in the card and connect it to the computer. Then try formating the card through Windows using the FAT file system (not NTFS).
SOURCE: My old memory card all
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
