I inserted a usb jump drive w/ all photos on, but it only displays in thumbnail - instruction booklet is hopeless. how do i change to full screen display?
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
SOURCE: I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
SOURCE: new xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
SOURCE: I have a Halina Digital Photo Frame DPF070B with
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
SOURCE: Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
