I made a password for my tablet and now i cant acssess my tablet at all
This works with devices having physical home button:-
1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
Reset factory setting from safemode menu,
check the video in my blog lol
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
SOURCE: forgot password
Tablet PCs aren't my specialty, but as long as you are running Windows XP. it should work like any other version of Windows XP.
Start up in safe mode and log on as administrator. If your computer is like most others, whoever set it up forgot to password protect the administrator profile. If so, you can log on as admin and go to users and change your password.
Good luck.
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
This solution works for
most tablets.
Power off the tablet
Tap Power, then press
and hold Power + Vol Down until you get a menu, then release
• Look for a Recovery or Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA, INCLUDING THE PASSWORD*
