I have a kenmore washer.Clothes keep coming out full of lint.cant seem to remove agitator.Is this where the promblem lies?Any tips on how toget this off?
Most agitators in top load washers are push on and hold on tight that way. There is space for you to insert fingers under the base of the agitator. Put fingers of each hand under opposite sides under the bottom, grab tightly, and pull up under control. The agitator should come out. Hope this helps. Unless you have the written instructions in your book that says otherwise. Good luck and let me know if it helps!!!
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap. If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint: 1. Turn clothes, particularly black clothes, inside out. 2. Use a concentrated soap with little or no filler. 3. Use less soap than normal. 4. Fully dissolve soap before adding clothes. 5. Run rinse cycle again after completing full wash cycle.
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint.
Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads. Eric
THE ONLY FILTERS YOUR WASHER HAS ARE LOCATED UNDERNEATH THE AGITATOR. REMOVE THE AGITATOR CAP AND TAKE OUT THE 7/16 BOLT DOWN IN THERE AND PULL THE WHOLE AGITATOR OUT. IN THE TUB YOU'LL SEE FOUR FILTERS AROUND THE AGITATOR SHAFT ASSEMBLY THOSE ARE THE ONLY FILTERS YOUR WASHER HAS. OTHER THAN THAT IT IS NOT THE WASHER CAUSING THIS PROBLEM. WHEN YOU WASH CLOTHES IF YOU CANNOT SEE THEM GOING DOWN IN THE TUB BY THE AGITATOR AND OTHERS COMING BACK UP ALONG THE OUTTER EDGE THEN YOU ARE OVERLOADING THE WASHER. HOPE THIS HELPS YOU.
You can go to www.shop.washermd.com and there is a downloadable tutorial for removing the agitator. You also may need to replace the agitator dogs. Dave
It probably isn't the agitator. Are you sure that it is lint and not the clothes getting torn up? One thing you might want to try is this. First take and pull the basket to one side and clean the gasket on top of the basket. There may be gunk built up on it that is transferring to your clothes. After you do that, just like a coffee maker, put about a cup of white vinegar into the washer and run a wash on hot water. After the load wash again without the vinegar just to make sure it all gets out. This is a good way to keep the washer clean all the time too, do this maybe every 3 months or so. I will clean any hard water deposits built up on the hoses and such and you will notice you clothes coming out cleaner. You can do this with your dishwasher too. Let me know if you have any other questions and if this was helpful to you at all. Good luck and I am glad that I could help you out.
The lint filter should be in the agitator. Pull the softener dispenser off the top of the agitator and check for a filter. You might even find that the agitator shaft is very dirty. Put through a warm wash with a solution of 1 cup vinegar to one cup bicarbonate of soda and let it go through complete wash. This should solve the problem.
