Originally replaced the nylon bushing at the base of the drum then shortly after the unit would not spin out the cloths so I put in a new pulley assebbly but am unable to get it to work properly it almost appears that the clutch spring may be too week, is this possible?
SOURCE: Washing machine will not spin dry but washes properly
If nothing is worn in that pulley/cam area then the transmission has gone out. Thanks, please leave feedback or contact me again for more info if you need it.
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
SOURCE: I have a Maytag top
I feel you need fix the root cause a Leaky Tub Seal. FAV6800A/FAV9800A Outer Tub bearing replacement See what is involved and iff you decide to go forward I will help on that forum. This forum is just to difficult to work in with no edit feature. The Clicking sound may be a broken Large Wrap spring. Place the washer with a load in the wash basket start a Spin Only cycle and release the washer top jus high enough to observe wash basket Spin action. There may be none to very little. If you drop the Clutch Pulley out I believe you will find much rust. You have to replace that tub seal and I would do a complete outer tub rebuild. Without replacing the Clutch Pulley around $60 for bearings, Tub and Seal Tranny O-ring. Review the post FAV6800A/FAV9800A Outer Tub bearing replacement and see if this is a direction for you.
Google this
