SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
SOURCE: The standby light keeps flashing, no display on my
CHECK THE CAPACITORS ON POWER BOARD, THERE IS PROBABLY AT LEAST 3 OF THEM THAT ARE SWOLLEN AND LEAKING, REPLACE THEM AND SHOULD WORK FINE
SOURCE: samsung 55" flat panel lcd
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
