Our Nordic Trac Tread mill tends to skip, **** every once and a while especailly at the beginning. I've tried adjusting and tightening the belt but it still happens.
Your help is appreciated!
Hi There, There is a StarTrac service bulletin concerning this issue. This is usually caused by the lower control board. Contact [email protected] for more help if needed.
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
1) test your circuit breaker home,reset 2)test the outlet for 115 vac 3)test the power cord if some wires is loose or cutting 4)reset your circuit breaker insider from your equipment 5)Eliminate any extension cord from your treadmill. 6)Be shure if the receptacle have ground cable with your divided TRSS.
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
my tread mill makes beeping noises during use.
machine run only 2 minutes
New tread mill but no safety key
e1 code appears on tread mill
