Question about Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television
SONY TV-MODEL KDL-46X2000-POWER
JUST TURN OFF ITSELF. NO POWER.
Anonymous
SOURCE:
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Posted on Apr 14, 2009
Anonymous
SOURCE: My Bravia Model KDL 46Z4500 (4 months old) turns
Replaced circuit board under warranty.
Posted on May 05, 2009
Anonymous
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Posted on Sep 14, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
How to replace brpken screen
Go and look on ifixit.com. There you find tutorials about how to fix almost anything. Then try to buy a new screen and look what it will cost. If you can buy one, it could cost lots and lots more than a complete new TV the same size or bigger. And then you still have to do the repair. and have an old TV.
Jun 22, 2014 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Standby light does not turn on
Sounds like a main board [motheboard] fault. Contact service center.
Aug 01, 2013 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Sony tv screen has no picture
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
May 25, 2012 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
Feb 22, 2011 | Sony KDL-46S2010 46 in. LCD Television
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KDL-40V5100 Switches off by itself
Sorry to say but it sounds like your power supply is bad, although it is possible it is some other components in the TV because turning it off allows all diodes etc to power down completely. Unfortunately after a bit it happens again which leads me to believe again power trouble.
Nov 05, 2017 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Nov 30, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sony bravia kdl-46x2000 have lost channell 7 how do I get it back
We phoned Sony direct who advised us on how to fix the problem
Nov 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
6 flashing lights
Similar problem with my Sony. I unplugged for 36 hours and it seemed to solve the problem.
Dec 28, 2008 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Open Questions:
See all Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Questions
Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
