You must do a "hard reset" in tis case, you will loose all the data you stored on the phone, the whole lot of it. So try and remember the PIN. If you are stuck then go to a local store of your service provider and they can reset the phone for free.
How to configure manually Samsung GT-S3353 Chat GPRS, MMS, Wi-Fi and browser settings
On your phone 'Menu' go to 'Settings'
Select 'Network'
On Network, select 'Connections'
You will be prompted by 'The menu manages connection profile. Incorrect configuration will prevent online connection.' message, just click 'Yes' to Continue.
On 'Connections' you can see all the list of Access points including Wi-Fi hotspots you connected.
Example: myGlobe Connect, myGlobe MMS, myGlobe Inet, Smart Internet, Sun GPRS, Smart MMS and FreePublic Wifi etc.
You can select which access point you want to edit manually, just point and click 'Options' then 'Edit'
If you want to create new access point for your network you can do it manually with your Samsung GT-S3353 Chat, just click 'Options' then select 'Create'
i have a samsung gt-s3353 mobile, the optical scroill pad has stopeed responding, there is nothing mentioned in the troubleshooting guide about it....pls help.
