How do you "RESET" the NVRAM on a Xerox WorkCenter 7346?
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
To reset the printers NVRAM using the Control Panel:
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
SOURCE: Xerox Phaser 8860 error code 04, 025,.46:0?
This fault code indicates a problem with the process control system.
Cannot successfully move the transfix mechanism to home position.
Check for obstructions around the Printhead. Look for ink blobs in gears of the tilt drive.
Clean any ink or debris which may be restricting movement of the drive train or Printhead.
