Many of the (early) Maytag Neptune washers had more than their share of problems. So much so, a class action suit was brought against Maytag; and they paid for repairs, replaced washers or provided credits toward new washers. Many of the problems were tied to the control board and "wax motor" door latch mechanism. Maytag charged $300 - $400 and up to replace the entire control board - when the parts on the board can be easily replaced for several dollars.
Anyway, you didn't include the nature of the problem you're having, so it's hard to provide any direction. It is normal for the board to become darker near resistors - but not burnt. Most problems are burnt resistors, triac and transistors - and of course, in my case - the "wax motor" that was responsible for the whole problem in the first place. It reported that the door wasn't locked - so high speed spin never took place. Clothes were wet and took a long time to dry as a result.
Provide as much detail as you can for the best answers. What does it do? what doesn't it do? strange noises? Has it slowly been getting worse? Does it smell? Do you use regular or HD detergent? I know some questions sound crazy - but knowing the answers to them does help!
SOURCE: Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
SOURCE: Replaced Motor Control, motor and Main Control board, but still won't work
The only other thing that could cause the ON light to turn off as soon as the motor is about to start would be a bad or loose connection that causes a break in the circuit. Even if the components are O.K. the connection could still be causing the problem.
SOURCE: Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
SOURCE: maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
SOURCE: Neptune MAH3000AWW washer will not drain
First and foremost unplug the unit
remove back panel
remove hoses from pump (expect water have towels handy)
open pump by removing screws
remove foreign objects if any
check impeller blades to ensure that they arent worn down
rebuild and reinstall pump
or replace pump reconnect hoses, replace rear panel
you should be good to go
