There is no release cable for the door behind the soap tray area.
If it has water in it it may not unlock the door, it depends on what type of door lock is fiited as it may be a pressure type. If you can get the outlet hose out and lower it below the level of the drum to drain the water that is in it then the door may open oncethe pressure is gone.
Thanks. That took care of the water & I was able to open the door. The problem was the impeller part of the water pump. 2 of the 3 blades were broken. I think something was blocking it. The whole unit had to be replaced at they don't make replacement impellers. Easy replacement & all is working great now. Thanks.
Glad you got it sorted.
SOURCE: Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
SOURCE: Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission. A $20 part
SOURCE: During spin cycle on Neptune TL, at around 12 minute mark, washer
Hi mgrey,
Thank you for the machine model number confirmation. Who ever offered up the clutch as a possible issue has a clue. Could be the Tub Displacement Sensor but from my experience 10 times out of 10 it’s the clutch. I’ll post this info as a solution, the next question is read the info look at the Service manual and see if you or someone you know that is handy can drop the clutch out of the machine and inspect. They can then evaluate the clutch to see if it’s what I call a soft failure, clean up and re-lube of the Clutch roller bearings. If the clutch roller bearings can be cleaned up and re-lubed and the clutch spring is not broken then you could be back in service today. If you call in a repair service and they have a clue and don’t shotgun parts into the machine the cost could be around $300+ for the clutch and labor. They won’t clean up and re-lube the clutch bearings. Please See this post for clutch maintenance it’s a recent post. I have some Pic’s that show the clutch and a replacement new clutch recommendation if it comes to that. I’m an owner of the machine and can offer phone support if you need. You can contact me at [email protected] and I can forward you a phone number. Post back anytime and I or someone will be there to help, I hope you can tolerate the down time, so many of these machines are junked for fix that is easy for the average DIY’er. Rich
I'll paste in the basic steps to follow;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
The Service Manual and Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Remove the front panel see page 41.
Tools required;
3/8 inch socket and socket wrench to remove clutch pulley bolt. Page 47 of the SM
1/2 inch socket or wrench to loosen Drive Motor tension bolt.
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM.
1. Lean the washer back and blocked in that position for a better reach angle. Rotate 3/8” clutch Pulley Bolt CW to remove clutch bolt.
2. Follow SM page 46 & 47 to remove clutch pulley.
3. Remove 4 screws holding plastic cover on clutch, inspect clutch spring to make sure it is not broken. Inspect roller bearings clean up with WD-40 and re-lube with bearing grease.
4. Replace white bearing plate into clutch pulley hub, insure key slot slips into clutch Spring pin in clutch hub.
5. Replace Clutch plastic cover with 4 screws.
6. Reseat clutch on spinner shaft and rock back and forth while lifting clutch with upward pressure to reseat clutch. When seated properly you will feel a 1/16-1/8" gap between the Pulley face and shaft end as mentioned and shown on page 47 of the SM. On reinstallation, tighten Clutch Pulley bolt CCW to 96” pounds 8’ foot pounds (Snug no torque wrench required).
7. Do a quick wash and make sure clutch runs true with no wobble or clicking sound. If the clutch has not been seated properly it will spin off. If this happens go to page 16 of the SM Board Output Test and turn on Drain Pump in Service Mode to pump out excess water.
8. Repeat steps 6&7 if the clutch has excessive noise or spins off.
Here are some folks that did this maintenance with positive results.
Positive Fix1/19
Positive Fix 1/18
Positive Fix 3/4
Positive Fix 3/4 different Forum
SOURCE: Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
SOURCE: Washer stops in mid-cycle, with a tank full of
I don't have the best news for your here. This type of problem is
caused by the timer, i.e. main control that you use to select cycles
starting to fail.
To start (if you haven't done this already) Pull out the timer knob and rotate it to spin and push it back in. If the spin cycle alone works, it will drain out the machine. If not there is the bail out technique for removing water.
If I am correct, when you put the machine into a
normal cycle, the knob rotates, but the machine is silent. Just sits
there. The older Maytags are a cut above many other machines on the market.
If you install the timer yourself, you will probably pay about $100.00 for the part.
If
you supply me with the model number and serial number, I can give your
some instruction on how to do it. They will be located on a placard
probably on the top rear of the machine. If my memory serves me
correctly
It is not a difficult job. does not require any expensive tools to do. If you do it make sure that the machine is UNPLUGGED FROM THE ELECTRICAL POWER WHILE CHANGING OUT THE TIMER.
Hope this helps,
Have a Happy New Year,
Mark
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open
http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
