I have a kurio 7 on the test bench with the same problem- shows a close to dead short between the battery connections on the board. a dc/dc converter chip in the charging circut is reading dead short between hot & ground. Marked XR1151 its a 6 pin sot23-6 package. I'm still looking for an place to purchase them.I have a kurio 7 on the test bench with the same problem- shows a close to dead short between the battery connections on the board. a dc/dc converter chip in the charging circut is reading dead short between hot & ground. Marked XR1151 its a 6 pin sot23-6 package. I'm still looking for an place to purchase them.
AnonymousMar 27, 2014
it wont turn off so i can restart itit wont turn off so i can restart it
AnonymousMar 28, 2014
it keep on freezingit keep on freezing
You can't post conmments that contain an email address.
I had this problem too. You can either use an android phone charger (easiest) or you can wrap the charger around it from top to bottom, still having it plugged in.
hook it to computer and go to the kurio site and have them diagnose it or they will send you a box to send it to them to be fixed or replaced,tell them its less than 9 months old
This is probably water damaged. You MIGHT get lucky with keeping it (powered off) in a bag of rice to wick the moisture out of the tablet and into the rice. Keep it there for a few days to keep it from getting damaged any further.
honestly idk what to tell you....I never fixed the kurio I just sent for a new one under warranty. maybe try holding the power and volume button on and off....it might work it worked for my kindle but its not the same device
1) do you get a charge light?
2) Do you have to hold the charger on an angle to charge
3) Has it been dropped?
If yes to two or more of these questions it sounds like you need to bring it in for service. You can bring it in directly to our shop for a FREE evaluation or send it in for repairs... sounds like it either it has been shocked through a surge or drop and/or charge/DC jack is damaged.
Thanks,
Rising Son
it keep on freezing
