HP Printer Error Code Cheat Sheet
Here you have the full list of error codes together with solutions, do check it out:
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: hp color laserjet 2605dn don't print correctly
surely,mirror laser scanner is so dirty,call expert for service cleaning.
SOURCE: 59 C0 error on hp color laserjet 5550
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
