The machine will start filling with water and then start emptying, then two lights starts flashing along with the power light. The manual said its a computer error, is there anything I can do to fix this? Please advise Many thanks
What 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
My Ariston A1636, 1600 spin washing machine is stopping half way through the cycle, full of water, and 2 lights are flashing along with the power button. They are the 'super wash' and 'rapid' buttons. Any suggestions please?
I have the same problem did you find a solution?
MIne too anyone have a suggestion? It will fill and usually wash,sometimes it will drain and spin. If it does drain and spin once it fills for rinse it won't drain or spin and all the lights will flash yellow really fast. I have to shut it down. I thought it was the pump but it seems to sometimes work and sometimes it won't.
Hi I have the same Ariston A1636 1600 spin and I have the on/off led flashing and the delay time does anyone know what that fault is at all?
My ariston also takes in water, then just as the drum would normally rotate, it drains the water and a the easy iron light flashes, along with the power light! I love this machine because even my teenage son can use it... a minor miracle i think! If anyone can help i would be so grateful, thank you.
two lights flashing along with power light no movement water still in machine
Hi I have the same problem with my Ariston A1636 1600 spin washing machine. When I start the machine the rapid light and the power light comes on, flashing. There is a sound of water entering the chamber but I see no water. Please advise.
Many thanks
Mr Vincent
when I turn the machine on it clicks but the water doesn't come in and the on light starts flashing
WATER DRAINS AS IT IS FILLED, WASH CYCLE DOES NOT START, THE TIME INDICATOR STARTS FLASHING AFTER SOMETIME.
