The timer standby light blinks 5 times
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal
deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have
failed. There are, for example, a few hundred parts and a section of
the Jungle IC chip involved. So, repairs could require something as
simple as replacing some inexpensive passive components OR as
complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
SOURCE: Sony KP-61HS10 blinking codes
From the Sony Customer Support web site:
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a
technician, as several IC and components must be tested and eventually
replaced.
SOURCE: sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
