My computer won't printer won't print. It says the memory is full. How do I clear it so I can print again?
Please do the following:
Cancel the print job if you want to delete the remaining data
in the printer memory. To cancel printing, press the Go button
while printing for about 4 seconds until all the LEDs light up. The
Ready and Error LEDs will flash as the job is
being canceled.
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
SOURCE: can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
SOURCE: Brother HL-2140 Corona Clean Error Won't Go Away!!!
The error message is misleading. The printer wants a new toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2140_all
SOURCE: HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Testimonial: ""Thank you so much! it saved me valuable money!!""
SOURCE: How can i set the Brother HL-2140 to print double
Check out page 22 of the manual located here: http://download.brother.com/welcome/doc002308/cv_hl2140_usaeng_usr_d.pdf
