Question about Sansui Televison & Video
Where is the fuse on my sansui LCD 24" tv?
There was a power outage and a red light will come on at the bottom of the tv but it will not turn on and show a picture with either the remote or manual buttons. I unplugged it for about five minutes and plugged it back up with no change. I then looked for a reset button and couldn't find one so I opened it up to find a fuse but can't find one. I don't know much about electronics but I know what a fuse looks like in a car and saw nothing like it anywhere. What do I do now?
    New Friend:
    Problem Solver:
  • 5 Answers
Contact the manufacture or open and look inside
Posted on Dec 27, 2012
6ya staff
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Hi, I have an rca 65 in led lcd. When i plug to wall outlet red light on front of tv comes on. When i turn it on (using control or tv button) tv screen flashes once (on left bottom corner). Screen stays...
If this is one of the first lcd TVs that set on a stand and are bulky in the back of the tv there is a place to change the tube it is a box and you will have to change it you can get on eBay and order the part I have one and have changed it a few times what happens to them is it comes in a box and if there is a power outage the little fan can't cool it off and they go bad if you still have your ouner ship booklet it will have instructions on how to change it isn't to bad to do
hope this helps
Dec 03, 2017 | Televison & Video
SansuiHDLCD4650 wont power up, red light indicating power to tv is lit.
The problem is in the Main board that also incorporates the T-con unit. Pull the main board out. Find IC 6201. Next to the two legs of IC6201, find Capacitor location C6212. Wick out C6212. Do not replace C6212. Your TV will come back to life! Thanks for asking, Matt of Martins TV Repair.
Aug 27, 2014 | Sansui HDLCD4650 LCD TV 46" - COWRIND...
My Sansui 32 inch LCD TV is not working
The main digital board stopped working. No SCL, SDA. Contact any service technician.
Jul 01, 2013 | Sansui HDLCD3250 32 in. LCD TV
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
I HAVE A SANSUI TV I GOT FROM WALMART 2 YEARS AGO. I WAS WATCHING THE OTHER NIGHT AND IT WENT OFF BY ITSELF. I CHECKED ALL THE CORDS AND EVERYTING IS IN RIGHT. I EVEN TRIED TO TURN IT ON BY THE POWER...
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_11_55_27_pm.jpg
Look at the power supply (follow the power cord) for bad caps that are puffed up like these are on top.
Apr 03, 2012 | Sansui 19 in. LCD TV
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Televison & Video Logo
237 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
