I just need some instrctions on how to replace the inner door panel on the DW.
Go on line with Bosh company and look up dishwashers giving your model. Request technical assistance to install the panel...
yes, thought of that, haven't got through yet. Thanks
Good luck, also, there might be someone on You Tube who has had the same problem..
finally got through to Bosch. Said I had to be a certified repair to get tech support. Guess I will just go for it.
SOURCE: Keep running at one minute?
well lots of times there is a mylar ribbion on the control panel that you can un hook and gently clean it with a pencial eraser as they are sensitive to resistance and lots of times this will fix it try it before the control panel im in the usa and havnt had a lot of hands on with bosch
SOURCE: bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
SOURCE: I have a Bosch SHU8805UC/14
Welcome to FixYa.
I believe the parts you are referring to are likely the blocks in each corner of the outer door panel. These have been a sticking point for many I tech over the years...I never understood why.
I digress.
If these are what you`re referring to, you can re-install them if you`d like but they really aren`t necessary for the function of the dishwasher and don`t have much effect to it`s decibel rating/noise level...perhaps a slight vibration reduction.
Here`s what you should be looking for...
If you examine them you`ll observe they have notches in the block that will slide into the door hinge frame only one way...
i.e.
As I alluded to though, they are really not needed for the machine to function proper and in fact are only present for structural support...as I`ve been informed through Bosch directly.
**Bosch built dishwasher no longer use these in the current machines being built...that should tell you something as well.**
Hope this answers your question or quells your concern. Let me know if I can assist you further.
Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
SOURCE: Whirlpool DU980QPDQ3: As per FixYa
Here are a few videos that may help
Click on the link http://www.youtube.com/watch?v=MDideDjjuEU
Click on the link http://www.youtube.com/watch?v=buxiEYOICWw
Ensure you have power going to the dispenser
Hope one of these works....let me lnow.
Keith
