When I put my quinny buzz up, the frame sticks and has to me forced open.
SOURCE: quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
SOURCE: does quinny dreami bassinet fit 2005 buzz frame?
Yes, you can!
Basically, the design for the Quinny Dreami has not been changed since 2002. So any Quinny Dreami since 2002 will fit any Quinny stroller/pushchair since 2002.
With kind regards,
www.Babycare.nl
Erwin de Raad
SOURCE: have a quinny buzz frame,
hi
the clips for the carrycot are marked left and right with small letters and when you put them on your frame the smooth bit of the clip should still be showing and the opened side of the clip should be facing each other and your carrycot should just go straight on to it
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
