The sound problem was first noticed when watching TV through a cable box. Replaced the cable box but did not help. Tested by moving the DVD player HDMI input to the "offending" input and now the DVD player also has faint and tinny sound. It appears that I have one HDMI circuit malfunction. Can this be repaired? Can the firmware be upgraded?
SOURCE: problems getting my ps3 to work with the reciever.
cheak setting in ps3 and use 720 p not all sterios handle 1080 p tranfer best u put ps3 directto tv then optical cable from tv back to sterio on a ch ok
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
SOURCE: HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
SOURCE: recently purchased this reciever, and in reading
It should work fine. The Pioneer VSX 1019 AH-K has been made so that it can accept 4 HDMI inputs (of which 3 are assignable, and 1 is for the BD player)
If you still have a problem, you can resort to the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. A lot of helpful guys out there, and a very active thread.
SOURCE: I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
