Hi got a nokia E5 have been able to download SIS file on it but got message "unable to install" or "file corrupted" during the installation process. what's the solution?
Try installing nokia ovi, whatsapp, ovi store , opera mini but in vain
Your phone has been infected with virus.I also had the same problem.Please enter *#7370# on your phone and restore settings and your problem is solved.Please don't forget to rate me as ' helpful ' if satisfied.
nokia E5 is symbian S60, yes, it supports java/.jar apps. and also .sis, just copy the application either cable or bluetooth, there are 2 ways in installing the file 1. via pc suite 2. on your phone,
This process erases from your Nokia 9300 all of your user data and
settings, including your phone book, calendar, email, downloads,
recordings, and certain factory installed programs such as Instant
Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some
basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC,
data cable, Bluetooth or infrared. For instructions see the Nokia 9300
User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite.
Please see the Nokia 9300 User Guide for general instructions to
install software using Nokia PC Suite, and follow those instructions
instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia
9300 with the appropriate software version. DO NOT install this file to
a Nokia 9300 with any other software version. DO NOT install this file
to any other model device.
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting. You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
* Remove the battery for 10 seconds * Replace the battery * Open the Nokia 9300 to view the inside display * When you see the screen with "NOKIA" in blue text, * Press and hold the following four keys until a Format Message is displayed: CRTL + Shift + F * Confirm the process by selecting Format * Formatting will begin * After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot * Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002 Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300. * Replace the battery cover (so the Nokia 9300 can read the MMC) * Open your device, then open the File Manager: Press the Desk application key Scroll to and select Office Scroll to and open File Manager * Using the arrow keys, scroll to Memory Card * Highlight the file install-cingular-default-603.SIS * Press Open to start the installation process * Follow and accept all prompts and requests * Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
May be the file u r download is might be corrupt so download from other location or tell me which sis file u want i will give u better download location.
I feel that the .nth (Nokia THeme file) that you are trying to install is corrupt. And secondly generally all software that are pertaining to mobile phones have .sis extention so ther should be no confusion. Try downloading the file from a proper source/site and retry installing it. I feel it should work.
1st make sure you have FExplorer installed on your phone. Generally the all software come in .sis format i.e. the installer files have a .sis extention. If u have a card reader, copy the .sis file/s that you have downloaded from the internet, into your memory card in the E:\Nokia\Installs directory & from there run the .sis file & during installation follow the instructions on screen. Read everything carefully before advancing each step. Also make sure that the software you are installing has come from a genuine source as it can be infected & can cause irreversible damage to your mobile phone.
