There is no such button with this remote control. Use the input selctor button [TV/AV]; instead. If you wish to get some details; check the site linked here. Pull up older posts. http://electrohelponline.blogspot.com/
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Codes to check with Daewoo brand TVs are 0038.0029,0059,0072,0019. If you wish to get more codes to Dawoo brand TVs with other brands remote controls, check this link. Not mind the brand of the remote control. Only look for codes for Daewoo with its code list.
Mi control es Quantum FX REM-200, y no tengo el instructivo para programarlo con una tele philips, y en todos las soluciones mencionan una tecla setup, pero este no lo tiene... Podrian ayudarme...?? Gracias....
Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
Using the number pad, enter 9-9-1. The TV key will blink twice.
Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
Press the SETUP key once to lock in the code. The TV key will blink twice.
