LG LHD65EBL Dehumidifier Logo
Anonymous Posted on Dec 29, 2012
Won't run has been working fine, but for some reason has stopped - no evidence of why... and it isn't the electrical outlet
Pump not working
If you've checked power to the pump and it isn't working, it needs replacing, unless it's blocked with slimy deposits. Try a vacuum cleaner on the drain hose outlet
The dehumidifier won't run. I adjust the humidistat up and down and nothing. worked fine up until that point.
Brad, there are several solvable things that can cause this:
1. The water collection bucket is not installed properly. Remove the bucket and reinstall it in such
a way that it fit's "squarely" into it's holder from top to bottom and makes contact with the bucket
safety removal switch on the back wall of the holder. When installed properly, the bottom of the
bucket will not tilt down at all.
2. The float valve in the top of the bucket (if yours is equipped) is either stuck in the 'UP' position or
float valve arm is broken. If it's stuck in the up position, jiggle the arm of the valve to make it
return to the 'DOWN' position. The float valve arm can be replaced if necessary. But in some
cases, you must purchase a new bucket with one already installed.
3. The outlet the unit is plugged into is faulty. Check your home's circuit breaker panel for a tripped
circuit breaker. If one is tripped, unplug the dehumidifier before resetting the breaker. If none is
tripped, check the outlet for power. It may have a loose or damaged wire on one of the terminals.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Dehumid....ad70usso....runs all the time auto settings don't seem to working collects fine ..but won't turn off when air is dry thanks
There are 4 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. Also, keep in mind, basements stay moister longer than upper rooms.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% and disable the auto mode.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Unit plugged in and no power. was wondering if there is reset or something elde to try? There is power to electrical outlet.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Our AD25THO. Runs fine but has recently stopped collecting water. It's dry as a bone and our basement is very damp. What's wrong with it?
heatman101
Compressor won't start,can hear circuit breaker clicking out. Fan runs okay,gauges reading okay.
heatman101
2helpful
My dehumidifier M3DH30B2A*A-R runs but no longer collects water. It had been set around 25-30 and run very well for two years but then suddenly began running continuously with no effect. There's no...
heatman101
Dehumidifier has stopped working...it appears to be electrical..no switches are working and no lights are on.
Check the outlet that the unit is plugged into, to be sure that it's still has power. If it doesn't, a circuit breaker for that outlet may have tripped. Or the outlet receptacle may have a loose wire. Try plugging the unit into another outlet that is not on the same circuit, as the one it's currently plugged into.
1helpful
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
2helpful
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
