Connect to the Apple imac
You need to check Compatibility with Apple iMac
Here is a link to Apple Support:
Welcome to Apple Support
SOURCE: need to connect my panasonic pv-gs80 to my imac
Best buy has brand new ones, or you could surf the web and find a cheaper one at like amazon. Just make sure that the size of the cable matches up with the size of your computer or else it will not be able to plug in.
The problem I have is like the other people, I got the firewire in the port and DV on the camera and my computer just doesn't recongnize it. Where's the solution to this? I have been trying to edit my film for over a year now with troubles with losing wires and now this and stuff. Hope this helps
SOURCE: new mac computer, panasonic vdr-d220 camcorder
If you're running OS X and you have iMovie (part of the suite that comes with Leopard) then your mac has a pre-loaded driver.
Just make sure the disc is finalized, then connect it to your mac via the USB cable and select the CONNECT DISC option on the camera. OS X will ask you which program to open it with; choose iMovie. It will open a video capture screen which will allow you to choose which scenes you want to load from the camera. It will take a few minutes to capture the files and save them to a project folder in iMovie; they'll be visible to work with in iMovie from there.
Note: I believe that iMovie converts the .VOB (DVD) files on your camera to .MOV (Quicktime), which can result in a minor loss in quality. But unless you have Final Cut or some other editing software, I don't know any other way to get those videos on your mac.
I have a VDR D220 and I've used it on a couple of projects with iMovie with success. Good luck.
SOURCE: I need a manual for panasonic nv-da1 camcorder
I have a Panasonic NV-DA1. New battery. It´s restarting on and on after some seconds, both on battery and connected direct to charger. It´s specially on record mode. Have changed tapes and cleaned the the tapeheads. What to do?
Ralph
SOURCE: Panasonic PV-GS35 will not connect to iMac, so
So if it's miniDV and you have a firewire cable, it should work. Have you followed this sequence:
If your battery is sufficiently charged to run the cam for an hour's worth of tape, fine, otherwise connect cam to AC power. With cam OFF, connect Firewire cable to Mac and cam. Open iMovie, name your project and create so that the viewer screen comes up. Turn on the cam. At this point, your Mac should, within moments, say "camera connected". Cam needs to be set on "playback" mode for capture. Then click "import" button and your Mac will control the cam.
If you still get a "no camera connected" you have to consider the possibility that either the firewire cable is bad or the firewire port on cam or Mac is bad. If you have more than one firewire port on your Mac, try switching. An Apple store should be able to help you determine if you have a bad cable or cam port, if you take both in to try on their Mac. Hope this gets you on track.
SOURCE: My Panasonic NV-DA1 Mini DV will not conntect to my PC, TV, or DVD recorder
I purchased a pluscom easy cap usb2.0 capture device,it comes with disc.Load onto your Laptop or Computer put in your number from disc cover and it will download a program that says VHS to DVD.Its all you need. connect your camera lead from the av out in side of camera it should have a red,white,and yellow plug on and connect it to your easy cap usb plug in then just push capture and your downloading. you have to have a play to select what files you want to save to but its easy enough. Its only taken me about 2 yrs to solve this download problem but all ok now.Good luck.
