HEADLAMPS AIM TOO HIGH
SOURCE: 2006 r1200rt engine cuts out during hard. bike works fine during
Hi..my name is Keith..and most new motorcycles has a thing called a "Rev Limiter"...and it if you push or rev it hard..it will make all kinds of popping and crackin noise and you will lose horse power..i dont know how hard you are trying to push your motorcycle..i hope this helps you
SOURCE: BMW R1200RT LE headlight alignment
I had the same problem. I'm doing this from memory, but there is a lever up inside the fairing which when flipped over will lower the beam to the correct spot. I found this solution in the owners manual, so for more precise directions check there.
SOURCE: Low beams on my 2006 r1200rt do not come on and
The power for the low beams starts at the dimmer switch. The power then travels on a black/green wire to fuse number 2.From fuse #2 the juice goes again on a black/green wire to the low beams. So, check if the power is getting to fuse #2 and that the fuse holder is OK. Check the black/green wires for breaks. Finally if you have no power to fuse 2 then check the dimmer switch itself.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
