SOURCE: ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
SOURCE: Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
SOURCE: my ice maker stop making ice,the water is ok,the
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
Thanks for contacting Fixya.
SOURCE: Had to disassemble ice crusher and lost order of reassembly
go to web sight . www.apdepot.com. put in your brand and model # look at the ice maker bucket assm. this will give you a picture af the proper assembly . pt # 12517801 .. **** .
Testimonial: "Great solution, AND NICE OF YOU TO BE SO HELPFUL! Thank you!"
SOURCE: MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
