I want to use my Samsung BD-C5500 Blu-Ray Player remote to control the power and volume functions on my LG television. There are separate power and volume functions specifically labeled "TV" on the Blu-Ray remote, however I cannot find out how to program that remote to control the TV.
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Unable to program Universal Remote. provided codes do not work.
Problem solved. I decided to use the learning function of my remote to learn the wanted commands of the original remote. The remote I used was a Sony RM-VL610 which could learn the original remotes functions easy and quickly. This is a very good remote for only $30 purchased at Target. The Macro commands were also entered rather easily. I did not try this method originally,because I thought it would be too time consuming and difficult.
pcwg
SOURCE: I have bouight a samsung home theatre system that
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
SOURCE: Contol Samsung Blu Ray BD-P1600 with Samsung remote
Compare the manufacturing dates and if remote is older, it is normal. If not, ask Samsung. Good chance
On blu ray remote control hold down TV Power+01 at the
same time. If the TV turns off the controller is programmed. If not, try TV Power+02,
+03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
