I live in close quarters with my machine and the high volume of the alarm signalling the end of a dryer cycle is too blaring for my small so I would like to disable it thanks for your help
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
SOURCE: washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
SOURCE: How do I separate a stacked washer/dryer combo unit?
Tried this before and is a major undertaking. The front angle panel has to be removed before you can access the rear panel, and then all of the electrical connections need to be traced and disconnected. This is a job for a tech and not recommended. I would suggest you measure, and then measure again and find a way to remove it in one piece, maybe even out a window if one is big enough.
