SOURCE: my sled loses power
Replace sparkplugs. Alsocould be a clutch or spark issue. Check the stator.
SOURCE: I have a 97' polaris xlt sks. Has been running
Matthau,
Please check if there is flooding in the carb. If not then may be it needs a choke as it must be running in extreme cold conditions.
SOURCE: have 96 indy 500 want to know what would cause the
IT COULD BE A NUMEBER OF THINGS, I WOULD CHECK YOUR DIVE SHAFT AND JACK SHAFT BEARINGS, THAN YOUR CLUTCHES FOR WORN PARTS. IF THAT IS OK CHECK YOUR CHAIN AND SPROKETS. THAN DO A COMPRESSION TEST ON YOUR ENGINE.
