I have sound bar and can not get any sound when hooked up to tv which connections do i use on back of tv if using rca cables
SOURCE: Zenith Plasma TV Manual
I found it posted here
MFL34797058_0.pdf
This is the web site...
http://tv.manualsonline.com/ex/thread/view/idThread/329713
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
SOURCE: Remote not turning the Zenith Plasma Display Panel TV on/off.
the remotes are usually multi function .. that is, they can control more than just the TV .. make sure TV mode is selected ... if its in VCR mode or Cable or whatever then it wont control the TV .. if its a programmable remote then it may have lost its program and would have to be set up again ... if its the original that came with the tv then that shouldnt happen . once in a while but not often i see a bad LED (at the tip of the remote) ... those are infra red so you cant see the light beam but a digital camera can .. point the remote at the digital camera and you should see the LED flashing in the cameras viewer when a button on the remote is pushed ...
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
