Hi My washing machine fills slowly when switched off. I think its the hot water inlet valve I have already turned off the water pipes, taken the hot and cold water inlet hoses out, cleaned the screens, and problem re-curs on replacing hot water supply and hose to the machine. Can any one give me specific advice on how to replace the inlet valve please?
If
your washing machine will not fill, only hot or cold will fill or is
slow to fill then read these tips. I have covered many of the things
that can happen in these tips...
Washing
Machine Problems No Water
Washing
Machine Fix Washing Machine No Water
heatman101
Hi, thank you, I shall give it a go and let you know how I get on.
Cheers
three inlet valves on washing machine
I have a lg washer/dryer combo..(wm3677hw)replaced hot & cold water valves now will not fill with water.please help Fern
wfw86hebw hot water inlet valve
the washing machine does not fill with water
My machine will not fill with water. I have removed and cleaned the inlet filter. Fresh start, set the cycle and press start... nothing happens.
i believe i have a water valve inlet issue but i can not get the back of washer off to check the valve and surrounding parts. this is a staced washer dryer with limited space for repair i have taken all the screws i see out but i must be missing something please help need clean clothes this is a frigidaire
I replace the inlet valve but it still doesn't fill water. then I found when I blow in the pressure switch the continuity doesn't change.
water inlet valve
No water going into machine when machine is switched on
Washing machine does not fill water. It shows only that the water supply is turned off.
model 20852991 serial# cl0602719
