SOURCE: bright green screen on samsung tocco
go to your network shop like 3 or O2 and ask them if they can fix it.
they fixed my other phone.
SOURCE: My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
SOURCE: I dropped my samsung in sandy ocean water about a
any water or liquid exposure on the phone will damage it's mother board. It needs to be fixed and needs a replacement on other parts on it, there is no assurance that it can still be fixed.
SOURCE: Samsung A707 Stuck at startup screen (loop)
No hard reset wont help!You should try following to get rid of this problem:
Thank you and good luck!
I had the same issue. Its hardware related due to no good contact between the phone and your tiny speaker.
To fix it no too hard.
1) Open up your Samsung infuse case directions here video http://www.youtube.com/watch?v=ewdyo2fkJj8
or pictures http://androidforums.com/samsung-infuse-4g/532693-how-fix-samsung-infuse-4g-screen.html
2) The speaker is located bottom left corner (two etched holes for sound)
3) With cover off locate 2 brass/bronze tabs that connect the phone to the speaker.
4) Slightly lift these tabs make sure not to far to brake off (1 mm)
5) Put back the cover and phone speaker should work fine
I hope this helps.
