After having successfully recorded once an instruction appears saying 'Cannot record due to incompatible format NTSC/PAL data on this card' - I have deleted everything from the card but still no joy? Any solutions\/
SOURCE: how do you delete multiple pictures from the
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
SOURCE: HOW DO I FORMAT AN SD CARD FOR MY PANASONIC LUMIX
be sure it is not blocked. (it has a locking button on the side) and after that into the menu of the camera look for format reset card ...this is the best way to do it cause it will format it on the way camera will support it ...Beware cause this will delete all your pictures..
usually the format feature will be on the view picture mode...around the option for delete single or multiple picks..
but if this is too hard ..just nsert the card into a card reader in a laptop or computer ...go to my computer folder...it will be seen as a removable storage device ..click right on it ..and than format ...choose to format in fat 32 not in ntfs cause the camera may not read it after that ..
so ...fat or fat 32 will be the mode...and if you have patience do not do it in the quick mode..cause it may cause damages in the long term ..(after a few times)
SOURCE: When I turn on my
Go to camera Menu and look for memory card settings/ format option, select format and press OK to format memory card.
